phosphate baseline issues
Posted: Thu Jan 05, 2012 5:36 pm
I am running 20 mM potassium phosphate pH 5.6 (I didn't develop method) with ACN gradient. Method uses 225 nm wavelength. Problem - many many ghost peaks in the baseline. I switched to Fluka HPLC grade phosphate/phosphoric acid - didn't help. I tried Empore C18 extraction disks to filter, but did not correct the problem. I saw a post that someone's 0.45 um membrane caused degradation and ghost peaks with pH 2.5 phosphate but not at pH 4.0, and switching filter brands helped. I could try switching brands, but since my pH is higher I don't think that's the cause. Any suggestions would be greatly appreciated!
Susan
Susan
