Sulfur impurities in Ethylene by PFPD detector
Posted: Thu Jan 05, 2012 6:34 am
I know a PFPD detector isn`t a linear detector and have a question for calibration. I have only one standard that mean one level calibration in 10 ppm. The software has some choices in calibration menu. Is it mandatory to select “quadratic” equation? in this case I should select “include origin” too. The real sample usually has lower concentration (below 1 ppm). Can I use “linear equation” for calibration?
Also another problem is big negative peak in PFPD detector for ethylene sample. is it a practical way to eliminate negative peak of ethylene which is main component?
