"EZ" Method Development in EZChrom Elite
Posted: Mon Dec 26, 2011 5:24 pm
Does anyone have a way to run method development sequences in EZChrom Elite without creating a different method for each condition? I'm working on method robustness studies for gradient methods using the DoE model. This often results in 40+ different methods when all factors are included (times, temps, flows, MP lines, etc.).
Seems like there should be a "Method Development Module" for EZChrom that allows the user to input method settings into the sequence (e.g. "Flow Rate" as a column in the sequence table), but I'm not able to find anything like this. Anyone have a good way around my "multiple methods" problem?
Thanks in advance,
Jon
Thanks in advance,
Jon
