When to change the column
Posted: Tue Dec 20, 2011 6:25 pm
Please let me know if there is a standardized procedure to follow to determine when do you need to change a column?
Is there a software that one can use to determine if there is a semnificative change in chromatogram that can compare an initial chromatogram with the current one to decide if the column needs to be changed.
Thank you
Thank you
