Can i determine the peak area by mannually calculating
Posted: Mon Dec 19, 2011 3:13 am
by seamoro
Can i determine the peak area by mannually calculating the peak area? i have some old data with no peak area...can i calculate from the chromtogram? how do i do this? thank you
Re: Can i determine the peak area by mannually calculating
Posted: Mon Dec 19, 2011 7:21 am
by Mattias
In the old days peak areas were determined by cutting out the peak from the printed chromatogram. The peaks were then weighed.
Posted: Mon Dec 19, 2011 7:14 pm
by tom jupille
You can also approximate it by triangulation, but Mattias' suggestion is better.
Posted: Mon Dec 19, 2011 8:11 pm
by Hollow
maybe you can also use the peak height for your purpose?
