1-cyanoguanidine(BP - metformin tablets test)??
Posted: Fri Dec 16, 2011 9:01 am
Hello
is Retention Time correct?
BP Metformin tables test 1-cyanoguaindine
column : whatman partisphere 12.5cm x 4.6 mm 5um SCX
flow rate : 1ml/min
mobile phase : 17g/L Ammonium dihydrogen orthophosphate adjusted to pH 3.0 With orthophosphoric acid
column oven temp :25°c
dectection wavelength : 218nm
injet : 20ul
test rusult
1-cyanoguanidine RT : 1.5min
metformin Hcl RT : 59min
what do you think about metformin Hcl RT?
flow rate : 1ml/min
injet : 20ul
test rusult
