Tetrahydrofuran stability
Posted: Wed Dec 14, 2011 2:03 am
Hi
I am required to use 80:20 [THF:H20] mix for my HPLC column. I am worried about the stability of the buffer as I ve read that THF being an organic ether has a tendency to form explosive peroxides on interaction with atmospheric oxygen. Can somebody please let me know how long I can store my buffer safely/normally on my bench without worrying about this problem? I am using the HPLC grade solvent without the BHT additive. The only other solution I got by calling tech support from the company I got the reagent from was to purge the bottle I am storing my buffer in with nitrogen or argon gas and to not use it/store it beyond 2-3 days.
