micro extraction
Posted: Fri Dec 09, 2011 5:26 pm
As you know typical GC injects 1 uL. If I extract sample into 1 mL of solvent and make injection out of this 1 mL I lose 1000 times sensitivity.
with the attempts of improve the extaction efficiency I am wondering: 1) what is the minimum volume needed in a GC vial/insert so the GC autosampler can make injections at least once? 50uL, 10 or 5uL?
2) If I have extract solution containing Trichloroanisole and blow it to concentrate into smaller volume, such as from 1mL to 50 uL do I need to worry about loss of the trichloroanisole(the analyte)?
3) another question in 2) is if there will be too much residual analyte sticking on the container wall, instead of dissolved in the solution? I am thinking 1 to 0.1 ug/mL concentration range.
