Agilent 7890: how to install a third detector?
Posted: Tue Dec 06, 2011 5:41 pm
Hi, ALL !
I have Agilent 7890 with 2 detectors (FID + ECD). I want to install third detector (NPD).
I know that you can set FID+ECD+TCD. Can I install FID+ECD+NPD? If not, why?
But I can not figure out where to attach the heater and sensor power NPD detector.
Heaters of all device (Inj 1, Inj 2, Det 1, Det 2, and heater MS-interface & sensors) connect to PIN № 21 on the main Board. This PIN is already busy.
PIN № 22 is free. I can connect my heater power cable to this PIN? This is a position 3&11 on PIN22 or 4&12? Where connect thermosensor?
Chemstation program will operate by heating the detector?
Does anyone have pics, looks like the connection 3 detectors to the Main Board? Or manual?
PS: Of coarse, we can attache the power and sensor NPD instead of MS-interface. But this is not exit from a situation.
PPS: Thank you for your attention to my bad english
