Determination of benzene at very low level in pure acetone
Posted: Thu Apr 21, 2005 12:56 pm
Dear all,
I have to measure trace of benzene in pure, pharmaceutical grade, acetone. My target is limit of 2 ppm of benzene. European Pharmacopeia describe a GC method that is: FID, column 50 m, 0.3 mm ID, 1 um film, stationary phase macrogol 20000R, split ratio 1:50, inj 1 ul.
With this method I should reach my low specification. I've already tried to make some tests with similiar method (FID, 0.53, HP-innowax, 1 um, 30m, spliut and splitless) but I can't reach this low level.
Can someone help me? Do you think that with the exact EP column I can reach 2 ppm level? Any suggest will be usefull.
Thank you very much.
