Help Newbie RE: macros
Posted: Thu Dec 01, 2011 4:48 pm
by rushrhees
Good afternoon all, I am relatively new to the field of Gas Chromatography (basically been tossed to the wolves in this field). Anyway, this is probably way to easy of a question for some but here goes. We have a GC method at that uses 3 macros to dump data to an excel file. I have all the macro files and the excel file. My question is how do I program the GC method so it will initiate those macros automatically after every run. Calling Chemstation's help files piss poor would be a complement to it in my mind.
Again thanks for helping a rookie out.
Re: Help Newbie RE: macros
Posted: Fri Dec 02, 2011 12:28 pm
by aldehyde
If you open chemstation, in the method and run control section (the main window) there is a menu at the top called method, and within that an option "edit entire method."
Do this and just click OK through each part until you get near the end, there is a window that lets you specify post run macros. Let me know if you can't find it.
