Urinary steroid hormone extraction - unusual IS abundance
Posted: Tue Nov 29, 2011 1:48 am
Hi all,
I am perplexed by the internal standard values I am getting for a couple of my urine samples. For example, I am only detecting 15% of the internal standard that I expect in my QC 12 samples. Why is this urine leading to such low internal standard abundance?
The LC-MS/MS method I am using is already validated by several others in my department. The QC urine samples are generated by individuals with healthy kidney function. I store all urine samples in the same -80C freezer. I have observed the same low ISTD abundance in QC 12 over the past two extractions.
I add the same amount of internal standard to all samples at the same time, using a positive-displacement pipette. I do a liq-liq extraction using Ethyl acetate. I evaporate under nitrogen gas while in a 30C water bath. And I reconstitute with 50/50 MeOH/H2O. I run this in ESI-negative.
Anyone know why I may be getting particularly low ISTD abundance on a single urine sample? Any ideas are greatly appreciated. Thanks!
Here is a clip of my numbers:
(A-D are various steroid compounds I am extracting. Each urine is extracted in duplicate.)
