Method for seprating "dirty" environmental samples
Posted: Sun Nov 27, 2011 5:13 pm
Hi there,
I was wondering if anyone could give me a detailed method for cleaning a "dirty" solution I have. I am investigating poly aromatic hydrocarbons in marine sediment. I have extracted the PAHs from the sediment using accelerated solvent extraction (ASE). I then used a turbo vap to concentrate my solutions, ready for injection into the GC-FID. However my supervisor said I need to perform some sort of chromotopgraphy on my "dirtiest" samples before I can inject them because they would get stuck on the column otherwise and clog the machine. One person suggested packing a heated pipette with silica gel and aliminium oxide and drawing the solution up into that. However he was not able to provide me with a detailed method and I have yet to find one in the literature either. If someone could direct me towards similar studies with methods detailing this process, I would be very grateful. Alternatively if you know a method you have used yourself that would be very helpful too.
Cheers,
Matt
Cheers,
Matt
