Pressure limits of columns
Posted: Sun Nov 27, 2011 4:39 pm
when I ask chromatography specialists about the pressure limits of columns, I often hear two answers:
- the "classical" 5 micron columns have a limit of 300 - 400 bar
- the UHPLC columns (sub-2-micron) have limits of 900 - 1200 bar
I often use columns with particle sizes of 2.5, 3 and 3.5 microns.
Is there a rule of thumb in which pressure range they can be used? Up to 600 bar? Up to 800 bar?
Thank you very much for every hint.
Florian
Florian
