Column cleaning for NH2 column
Posted: Wed Nov 23, 2011 12:20 am
Hi All,
I saw this column cleaning procedure from a vendor saying that I should clean my NH2 column using 30 column volumes of NaOH at pH11. The pH range of the column is 1-11...why does this not harm the column? I thought holding the pH at the limit of a column's pH range would drastically decrease its lifetime. Is NH2 different?
