volume of sample to load on column??
Posted: Mon Nov 21, 2011 8:36 am
by Farah Saleem
Dear all,
I am working on the separation of bacterial beta galactosidase enzyme from the mixture of protein sample. Doing conventional gel filteration chromatography for this purpose. Resin is Sephadex G-100.
Kindly suggest me how much volume of sample should i load on column?? My sample contains 1.2 mg/ml of protein.
Column height is 80cm and width is 2.2 mm.
Kindly reply as soon as possible.
Re: volume of sample to load on column??
Posted: Mon Nov 21, 2011 2:47 pm
by Kristof
Less than 5% of column volume, around 1-2% should be OK.
Posted: Mon Nov 21, 2011 9:49 pm
by ScottHorn
Double check those column dimensions. Are you sure you didn't mean 80cm by 22mm? Otherwise that sounds like a very impractical column for your purpose, which I'm assuming is prep scale. Also, that would be an incredibly fragile column.
Posted: Tue Nov 22, 2011 5:54 am
by Farah Saleem
thanks for your reply
