Formaldehyde detection
Posted: Sat Nov 19, 2011 6:56 am
Evening,
I'm in the process of doing some comparisons to my own research and am trying to figure out why this particular product was not mentioned in this paper when during a duplicate experiment I performed it was produced in great quantities. The chemical in question is formaldehyde - in this paper it looks like a liquid analysis was performed using a supelcogel-H HPLC column with a refractive index detector with 0.1% phosphoric acid as the eluent. Is it possible that formaldehyde is unable to be detected by an RI? or is it more likely that their method was not run long enough to reach the retention time of the HCOH? In this paper acetic acid and methanol were also successfully analyzed using this column and whatever method they used. Any wisdom would be greatly appreciated.
thanks!
thanks!
