HPLC HP1090
Posted: Mon Apr 18, 2005 1:28 pm
Good afternoon! I started to work with used HP1090 which does not have proper manuals, and I have several questions. I did not find purge/prime system, so I just remove the column head to purge. Is there a purge system? How the injection system and the needle washed? Are they always connected to the flow? Is there some special procedure to wash the pump? I have some “pumpâ€
