LOD LOQ HPLC Agilent 1200
Posted: Sun Nov 13, 2011 9:58 am
by push
I use to calculate LOD=3x(Signal to noise) and LOQ=10x(Signal to noise).
Whai is the meaning of S/N parameter in Agilent 1200 Software?
How far from the peak of analyte you chose a base line for noise measurement?
Re: LOD LOQ HPLC Agilent 1200
Posted: Sun Nov 13, 2011 5:05 pm
by tom jupille
As close as possible.
That said, in my (not so humble) opinion, S/N is adequate for *estimating* LOD or LOQ, but a poor way to *calculate*, for just the reason to which you allude: where do you measure noise? how long a stretch of baseline is required? what happens if you have other peaks near the analyte?
There are far better approaches:
- statistical (based on the standard error of the y-intercept)
- CV vs A plots (especially for LOQ, since this allows the precision requirement to be accounted for).
Posted: Sun Nov 13, 2011 7:27 pm
by push
Thnks,
I just do no understand about CV vs A. What are those?
Posted: Sun Nov 13, 2011 8:27 pm
by tom jupille
CV is "coefficient of variation", also sometimes referred to as "RSD" ("relative standard deviation"). A is analyte amount (or peak area or height). In a CV vs. A plot, you run replicates at various levels across the linear range. A log-log plot of CV vs A will typically be horizontal at relatively high amounts and then curve upward to the left for smaller amounts. Where that plot crosses your target CV tells you the LOQ.
Posted: Mon Nov 14, 2011 7:31 pm
by surinzp
Hi Tom,
i am doing a linearity experiment, i draw the linearity graph between area and concentration in ppm and i calculate the LOD and LOQ from the linearity curve. My question is in what units i get the LOD and LOQ values?If i want to change the units from ppm to % how do i do that.Could you please explain.
suri
Posted: Tue Nov 15, 2011 3:31 am
by tom jupille
LOD / LOQ will have the same units as your x-axis (ppm, %, mg, ng, . . . whatever you used).
% = parts per hundred.
ppm = parts per million
so, 1% = 10,000 ppm
Posted: Tue Nov 15, 2011 3:24 pm
by HPLCaddict
so, 1% = 10,000 ppm
I'd be careful about that. I've often seen "ppm" used as mass per volume concentration unit. So 1 ppm = 1µg/L (with the background that 1L of water should weigh 1kg = 1,000,000µg). Although this is true only for purely aqueous solutions, it's often used for solutions including organics of any kind.
"%" on the other hand is often related to the "normal"/100%/whatever-you-call-it concentration of the sample.
So, if your sample is e.g. 0.5mg/mL (=100%) = 500µg/mL, 1% would be 5µg/mL. 5µg/mL = 5,000µg/L would tranlsate into 5,000ppm!
Posted: Tue Nov 15, 2011 3:34 pm
by tom jupille
Good point, but I wanted to avoid the whole debate about whether "ppm" or "%" make sense (the inherent ambiguity makes them very poor choices!).
Posted: Tue Nov 15, 2011 4:24 pm
by HPLCaddict
Good point on your side, Tom :D !
Posted: Tue Nov 15, 2011 9:31 pm
by Blazer
This is a debate I'm currently having here, "which is better?" or rather, "which is preferred by the FDA?". Or even, "do they have a preference?".
In a recent validation I calculated the LOQ experimentally using S/N as 1ppm. When I calculated the LOQ statistically based on the linearity data (as per the ICH, 10*sigma/slope), I got a value of 31ppm. I was hoping the two LOQ values would be closer together so I could say that it didn't matter which method was used, but the discrepancy between the two doesn't please me.
Posted: Wed Nov 16, 2011 5:19 am
by surinzp
so, 1% = 10,000 ppm
Thanks very much Tom,
i am just estimating the linearity and LOd and LOQ by just using the standards.I am not using any spiked test samples. which way would be most appropriate?
Posted: Wed Nov 16, 2011 4:00 pm
by tom jupille
Spiked matrix blank would be the most appropriate (more representative of real samples).
