Taken over method development project from a colleague..help
Posted: Fri Nov 11, 2011 5:31 am
Hello, I have taken over method development project from a colleague(he has left the company)...and i need some help.
The work he has previously done was on LCMSMS. he has given me a brief description:
Ionisation mode: negative
Column:Phenomenex Aqua C18-50mm x 2.0mmx 5μm
Buffer: Water and acn with 0.1% formic acid and 5mM ammonium formate.
From the data above what does he mean by ionisation mode mean? and the formic acid is to adjuct pH and the ammonium is the buffer to retain pH?
