As per request of Rob Burgess & in the interest of forum members following are the conversations had with Mr.Bhaskar regarding the Response factor:
Dear Bhaskar,
You can either way express the response factor. If you are considering the salt form in calculation then you needs to document it as like response factor due to IMP (Impurity base) with respect to XYZ.HCl (or salt) is ABC depending upon your calculation consideration.
Or it can also be transformed in to base as response factor due to Imp (Impurity base) with respect to XYZ (base) for XYZ.HCL salt.
The reporting will depend on the claims of your product and/or standard practice of your laboratory.
I think this will clear your confusion.
Confirm me receipt of this mail.
Hemal Bhavsar
Dear Hemal,
Thanks for your response. We are facing the problem where our customer is calculating it as base in his drug product(ie.Almodipine besylate), where as we (API) considering it a besylate salt.
Best regards,
Bhaskar Reddy
Dear Hemal,
Even ICH guidelines clearly mentioned that Response factor must be calculated with ''drug substance'' only.
Please find the below material from ICH Q3A. (Embedded image moved to file: pic25667.jpg)
At the same time ICH dfines the Drugsubstance as below.
(Embedded image moved to file: pic26299.jpg)
So what we say is the response factor must be calculated as amlodipine besylate only, not as Amlodipine base.
Please comment.
Best regards,
Bhaskar Reddy
Dear Bhaskar
It's always preferable to calculate response factor in terms of salt form. Since both in API & Drug product we are using the API salt as reference standard instead of impurity & applying the response factor. So while calculating, the % Impurity in API we get directly as % of Salt form & that is desired as per regulatory requirements.
Confusion mainly arises where the label claim for drug product is in terms of base; as in your case also .
Even if the drug product is claimed as base one should consider the response factor w.r.t. salt since this does't require to consider the molecular weights of base & that of salt in calculation formula. Since consideration of response factor in calculation is use of API salt instead of impurity.
Hemal Bhavsar
