Piperonyl Butoxide Issue
Posted: Tue Nov 08, 2011 9:50 pm
by SamC489
I currently and working to develop a method for pesticide quantitiation of in-house formulations as a QC check. I am using an Agilent HP-5 30m x 0.32mm x0.25 um. The method I am writing analyzes for Tetramethrin, Permethrin, Sumitherin and Piperonyl Butoxide. I get accurate, reproducable results when analyzing both raw materials and individual batches for Tetramethrin, Permethrin and Sumithrin, but I am getting between 92% and 95% recovery for Piperonyl Butoxide, only in raw material and batch samples. I have made several method check standards from two different standard suppliers, and when I run the check standards, they are +/- 1% of the theoretical. There is no obvious interference that I can see. If it was my column or GC, the check standards would show the same low recovery, correct?
Has anyone had experience with this?
