Question about graphitized carbon column
Posted: Fri Nov 04, 2011 5:24 am
Hi Everyone,
I met a strange problem recently when I was using graphitized carbon column for separation. Since I am still in the method test step, so I just used peptide mixtures for LC-MS analysis. The mobile phase I used are A: 0.1% FA in water (pH=4), B: 0.1% FA in ACN. I also tried the 40mM ammoniu formate (pH=4) in buffer A, but no big difference observed. The gradient I tried were 3%B-80%B or 3%B-100%B in 10, 20, 30min. At the beginning, I tried some standard peptide mixtures (angiotensin, bradykini, etc), but under all above conditions, I just never saw the signals! Even I put the concentration to 10pmol, 100pmol injection, I still didn't see evident signals. With the same settings(mobile phase, gradient), all peptides have good signal in C18 column. Then I switched to BSA digest, it seems only 3 peptides appeared, all the other 10 abudant ones I found in C18 also not detected.
I used direct injection to mass spec, so no trap column used, according to my results, the only explaination I can have is most of the peptides are either still on the column even I use 100%ACN for 20min washing or those peptides were diluted by the carbon column? I am really confused.
I am really new to use graphitized carbon column, can any experienced users give me some suggestions on my strange observations? Is this normal or not for peptide case? Although I know the graphitized carbon is used for hydrophilic compounds, such as glycans. But I have limitted glycan materials, so I am still using peptides for testing. Do I make anything wrong?
