Oxidation problem in protein analysis
Posted: Mon Oct 24, 2011 5:44 am
by brazdzionis
I have a problem with oxidated forms in my analysis. We are using H2O + 0.1% TFA as solvent A and ACN + 0.1% TFA as solvent B, C18 waters symetry column. I'm analysing a specific protein all the time, and when I do my system routine check with reference standart, oxidised protein forms should be around 0.25 - 0.40 area%, but something has changed now and it's around 0.5-0.6%. I have rechecked everything, solvents, precolumn, column what causes may result this?
Apreciate your help.
Re: Oxidation problem in protein analysis
Posted: Mon Oct 24, 2011 4:16 pm
by Kristof
Have you considered storage conditions of samples? Temperature, pH, buffer composition, time?
Posted: Tue Oct 25, 2011 10:46 am
by brazdzionis
Yes these factors have been check already, something is deeper than that
Posted: Wed Oct 26, 2011 1:38 pm
by carls
A detailed investigation of peptide oxidation in autosampler vials is given in the thread below. Many oxidation sources were tested. Maybe this will give you some ideas.
viewtopic.php?f=19&t=13785&hilit=peptide+oxidation
