HOW MANY DIODES ARE ENOUGH?
Posted: Tue Oct 18, 2011 8:07 pm
THANKS FOR REDING THIS FELLOWS
I WOULD LIKE TO GET ANY OPINION ABOUT . WHAT IS THE APROPRIATE NUMBRE OF DIODES THAT A PHOTODIODE ARRAY DETECTOR SHOULD HAVE.
FOR EXAMPLE PERKIN ELMER HAVE ONLY 512 DIODES AND THE REST OF MODELS IN OTHER MARKS HAVE 1024 DIODES. WHATS THE DEAL WITH THESE. I READ THAR THE RESOLUTION COULD BE THE REASON.
RESOLUTION = (WL 1 - WL 2) / number of diodes
For example if I calculate this for PErkin Elmer (Flexar)
Resolution PE = (700 nm - 190 nm )/512 diodes = 0.996 nm/diode
(reported as 1,09 nm /diode by Perkin Elmer)
For the others I have, for example:
Resolution OT = (900 nm -190 nm) /1024 diodes = 0,693 nm / diodes
Aparently the second one is the best BUT IN BOTH OF THEM the wavelength accuracy is 1 nm. So no matter if the resolution is 0,693 nm / diode because the accuracy exactitud is always 1 nm.
IS IT RIGHT WHAT I THINK???? PLEASE I NEED SOME ADVICE ... I AM LOOKING FOR AN ANSWER OR AT LEAST AN OPINION.
THANKS SOOOO MUCH FOR YOUR HELP
