Baseline drift problem
Posted: Wed Oct 12, 2011 2:02 pm
Good afternoon,
I am having some trouble in one current method we use to quantify some anti-infeccious drugs from plasma samples. We use an Acetonitrile:Phosfate Buffer gradient by 25 minutes at 215 nm, witch results in a perfect separation of peaks. Our system is an Elite LaChrom and the coullum is an Waters Sunfire. The method had a normal drift of baseline, as the acetonitrile proportion rises up, at max 0,005 mUA, witch we accept as rasonable.
Last week we exange the collum to try a new method on an Waters Atlantis, and when we put the Sunfire back in the system and calibrate the anti-infeccious drugs method, the drift get up at max of 0,2 mUA, witch is incompatible with our LLOQ.
What could be causing this?
