HILIC for a n00b
Posted: Tue Oct 11, 2011 3:46 am
Hello all,
I'm back to using HPLC again after a significant sabbatical away...
We're a low throughput lab (with regard to HPLC quants at least) and we get a lot of one-off requests. I'd like to explore the potentiality of HILIC as it will be another technique we could use for the polar/ionic compounds.
Reading through the literature it seems that bare Silica HPLC columns can be used for HILIC with aqueous RP mobile phases e.g:
http://www.sigmaaldrich.com/etc/mediali ... 10093h.pdf
http://www.labplus.co.kr/tech/uploadHTML/HILIC.pdf
Is this true? I'd always presumed that a specialist bonded phase was necessary.
In the dim dark past I've never run anything more polar than neat IPA through a bare Silica column. I also remember from my graduate student days that when I ran a flash column with more than 40% MeOH/DCM I'd get a white precipitate (which I presumed to be Si) which I'd have to filter from my purified natural product. I realise a bonded phase is different from the TLC grade Si we'd use for our homemade flash columns but all the same...
I have a donated Hypersil Silica 5um (4.6 x 250 mm) column that can be sacrificed if the need be. Can I give this a go, or will the stationary phase be stripped off?
Just wanted to ask before I have a play around and attempt to get a feel for this technique.
Many thanks in advance.
