pump seal failure
Posted: Mon Oct 10, 2011 2:54 pm
ı have been working in agilent 1200 systems. my method is containing reversed phase solvents.
ı change my pump seal every 3 or 5 mounths. ı think this time span is lower life for pump seal. ıt reduces a big cost for our. my shut down method containing a acetonitrille. ı red a article about pump seal ' higher acn value can reduce pump seal because acn to wet the pump seal surface than meoh'
what is the possible cause this problem?
thanks every body.
thanks every body.
