Use of C of A for Purity of Codeine Phosphate Standard
Posted: Mon Oct 03, 2011 8:29 pm
We recently ran an Assay method by HPLC for Codeine, using a USP reference standard for Codeine Phosphate. The purity of the standard is indicated as 99.8%, but the standard method of analysis is by titration. If an the peak purity was determined just by the areas on the chromatogram (there are a number of small peaks in addition to the big drug substance peak), the purity might be more like 98.6%. There is an obvious flaw in trying to use a purity value obtained by one method (titration) for another method (HPLC).
Does anyone know a reputable reference standard supplier that sells Codeine Phosphate with the C of A determined by chromatography?
For Clarification, I should add that this is for an Assay analysis, with the specifications of 98.5% to 101.5%. Therefore, a change in the purity factor of the standard of < 1% can easily mean the difference between passing and failing.
