Not able to see select over lay window
Posted: Fri Sep 30, 2011 1:10 pm
Good morning, I am new to GC-MS and running a method using FID method for blank and high neat cal. I have loaded the data file in GC-Data Analysis and it was loaded as usually.
From there I went to view, chromatogram overlay: the real problem is select over lay mode window doesn't shows up. On the opened data file it shows : view mode: integration.
Does anyone has this kind of problem, any suggestion to resolve this issue?.
Rao
Rao
