analysis of O2-N2-CO-CO2-CH4 in pure HCL
Posted: Tue Sep 27, 2011 2:14 pm
by tiger1076
Can you please let me know which column to use for the analysis of O2-N2-CO-CO2-CH4 in pure gaseous HCL?
packed or capilary?
thanks
Re: analysis of O2-N2-CO-CO2-CH4 in pure HCL
Posted: Tue Sep 27, 2011 11:17 pm
by chromatographer1
which column to use?
No one column will suffice.
At least two would be necessary.
Posted: Mon Oct 03, 2011 5:52 pm
by tigerk2001
Hi Rod,
I mean which configuration.
I have in mind hearcut with pre column and 5A for permanent gases separation. What would be the pre column?
Which material?
Also, SS isn't recommended cause of corrosion with moisture.
Do you think peak column could be good instead of using SS?
I want packed column if possible
thanks
Tiger
