IC- higher than expected peaks - DX500
Posted: Fri Apr 08, 2005 9:54 am
..for smaller than expected analyte peaks there could be a bunch of reasons; for higher? We're using a DX500 for major anions, org. anions and cations analysis. We're currently running anions using AS-9 by Dionex (low-level concentrations), and we've been very pleased with the performance of the system.
The only thing changed before this rise in the peaks height/area was observed ,was the stock solution from which we make our eluent. However the new stock was prepared in a decent way, with 18,2 MΩ-cm water, and the background conductivity we see for our eluent when running it, is the same as before. Retention times of the compounds are also the same as before. However, the peaks have increased we have been checking it with our standards which one day before yesterday were giving extremely good results (accuracy <=3% from theoretical values) (and nothing has been touched in the data acquisition software in the pc, regarding attenuation of the signal and so).
Any ideas/suggestions would be more than welcomed.
