HILIC at low pH
Posted: Thu Apr 07, 2005 12:36 pm
Does anyone know which UV transparent acids can be employed (at 200-205 nm) with a silica column in HILIC mode? I believe I saw some mention of the incompatibility of phosphoric acid but I do not understand why. What might be typical acid contents in this mode vs. reverse phase (0.05 - 0.1% v/v ok?)
Is it common to use higher concentrations of buffer in HILIC (with UV) mode than, for eg., when employing an MS detector. Again, I've read many application notes where 100 or 200 mM of formate or acetate buffer is used, and am curious how this affects the retention mechanism if silanols are fully protonated on a high purity silica at pH ≤5.
thanks.
thanks.
