Contamination following Florisil cleanup
Posted: Wed Sep 21, 2011 9:20 pm
I am currently analyzing plasma and tissue samples for a select number of PCB congeners on GC-MS in SIM mode. Our sample prep procedure involves extraction into 1:1 hexane:acetone; concentrating; cleanup by 5000 mg Alltech (Grace) Florisil SPE cartridge with 1 g of Na2SO4 and a concentration step
The SPE step consists of the following: Precondition with 12 mL of hexane, Loading of ~0.5mL sample plus 1 mL rinse and finally elution with 3 rinses of 4 mL of hexane.
This cleanup procedure resulted in a lot of noise when spiking clean samples with PCBs, and we found that the SPE was causing a significant amount of noise and interference (see the below chromatographs of a hexane blank and hexane blank ran through the SPE cartridge.) Does anyone have any recommendations on how to eliminate the noise, or different types or brands of SPE cartridges that reduce it?
Thank You
Thank You
