Static HEadspace problem
Posted: Mon Sep 12, 2011 2:09 pm
I could use some clear heads, as I have been beating mine for the last 6 weeks or so.
We are trying to qualify a new headspace blood alcohol method usin a Tekmar HT3 ( loop only) and an Agilent 6890 fid.
using a DB-624 column 30M X 0.25 X 1.4 @ 2 cc/min. The Headspace has a 1 ml loop and I am splitting @ 60:1.
THe headspace is set for constant heat for 20 min @ 65C.
My compounds are Acetaldehhyde, MeOH, ETOH, Acetone, IPA, t-butanol ( surrogate), and n-propanol ( IS).
What I have been fighting is I get a 40% or so drop for all compounds between injection 1 and 2, then from 2 on the areas stay consistant. Nothing I've tried has made any significant improvement. Those changes have been: rebuilt lower part of the injection port, swapped EPC's, different column ( same phase but 60M), new FID jet. Tekmar sent me a loaner and data is still bad, but pattern is different.
We have been running the method on a Tekmar 7000, and Agilent 5890 using most of the same parameters and it is rock steady. This setup uses a 30 X 0.45 X 2.55 DB 624 at about 7 cc/min using a packed inlet. The Tekmar has a 100 ul sample loop.
What am I missing??
What am I missing??
