GC Chemstation Instrument Fault Detection
Posted: Sat Sep 10, 2011 7:18 pm
by brummie99
Anybody know of a hook or macro code that could get triggered whenever an instrument fault is detected e.g. autosampler fault or communications fault causing the sequence to stop?
I want to insert some code that triggers an email to be sent whenever an instrument fault occurs.
I'm using version B.01.03
Re: GC Chemstation Instrument Fault Detection
Posted: Mon Sep 26, 2011 4:10 pm
by LabProARW
I would love to be able to do this too! In my playing around with the macros I had difficulty finding where to 'insert' them or 'load' them from inside of Chemstation. When I found one place in the pre and post sequence run page I learned that if someone aborts the run then the macro did not launch. My macro found the data file - renamed it - moved it to a 'hot folder'. Again when a user decided that the run had gone long enough and told it to stop, my post run macro did not run.
Posted: Fri Oct 07, 2011 1:34 pm
by MX304
From what Agilent has told me, no, it isn't possible to set up alerts like that.
Posted: Wed Nov 02, 2011 9:08 pm
by george_jibuti
From chemstation it is not possible, but I thin Agilent Lab Monitoring And Diagnostic Software has such function
(Basic edition of this software is free and comes with instrument)
