How to improve peak shape of tetracyclin by LC/QQQ
Posted: Mon Sep 05, 2011 3:08 pm
Hi all,
We are analyzing tetracyclin by LC/QQQ. The peak is not so good, it's rather tailing while the application shows very nice peak.
Our conditions are:
Column: RP C18 : 50mm, 2.1mm, 1.8 um
Mobile phase A: H2O + 0.1% formic acid
Mobile phase B: Acetonitrile + 0.1% formic acid
Gradient: B% = 5% at 0 min. and increases to 95% at 4min.
Injection volume : 5uL
MS/MS:
ESI positive mode
dry gas: 7L/min, temp = 350 oC, Vcap = 4000, nebulizer = 40 psi
MRM: 445 -> 410 and 445 --> 154.
We have tried many times and it improves a little bit but not as good as the peak in application. Have we done something wrong and what can be done to improve the peak shape.
Thanks for any helps.
Here I post the best peak that we could get:
http://farm7.static.flickr.com/6071/611 ... b725_z.jpg
Our conditions are:
MS/MS:
ESI positive mode
