525.2 is a peculiar method...i've run the entire gammut, from phthalate contamination to poor endrin breakdown to analytes disapearing... only to show up again in the next lfb.
1. clean the inlet
2. use focus liner
3. I exctract and concentrate in as low light as possible
4. muffle EVERYTHING!!! anything glass should be washed and muffled, even if you opened a brand new box... really it works.
5. I let the water and meoh sit on the column for about 20 min. prior to starting the extract...then i let the 1:1 EtoAc:DCM set for 20 min during elution...that has seemed to bump up recoveries on some problem compounds.
alot of the people on this forum are great resources...
hope this helps some.
