Phytosterol esters in complex matrix
Posted: Fri Apr 01, 2005 7:33 pm
Has anyone else dealt with phytosterol esters analysis by HPLC?
I have used GC for this type of analysis before, however it was a mess, derivitization using MSTFA in pyridine. Columns tended to die rather quickly because of the high temps required to get a separation. This is not a usable method for me anymore because I am now testing for phyto-esters in a matrix that is mostly fish oil.
Now I have been working with HPLC, UV detection at 204nm, using isocratic ACN:IPA.
The problem is this: To get a good separation from fish oils and phyto-esters I need selectivity that will separate the fatty acids from the phyto-esters. With column selection I can get a separation of oil from phyto esters, but without selectivity between related pairs of phyto esters that have varied fatty acid ester groups.
The best column I have found so far gives me a separation of phyto esters from fish oil components but leaves my phyto-esters in a series of partially resolved groups that I suspect only vary by their ester group.
This is Phenomonex's new Gemini column 5u C18 250X4.6. Has anyone else done any work with a separation that requires two different types of selectivity?
Rick
Rick
