Guide for preparion of standard solution
Posted: Tue Aug 30, 2011 8:12 pm
Friend of mine looking for guide for preparation for standard solution. Two main topic should described:
1. what MAXIMUM dilution factor should be used (10x, 100x, 1000X) in preparation of working solution from stock solution ?
2. why using very small volumes of pipette (like 1 ul) can cause errors?
Above problems are relatively obvious, but I can not find any OFFICIAL document (FDA, EPA, ISO.???) describing it.
Thanks in advance!
Thanks in advance!
