GPC column
Posted: Tue Aug 30, 2011 6:26 pm
by sepscientologist
Would anyone like to recomend a GPC column? I am analyzing polyesters with a Jordi Xtreme column
currently but want to try something else. Polymers are up to 3 million MW and solvent is HFIP.
Re: GPC column
Posted: Wed Aug 31, 2011 8:54 am
by Gerhard Kratz
If you google for GPC columns you will get information on all manufacturers and suppliers of GPC columns. It is impossible to recommend a GPC column. We would need to know from you what do you want to improve, why are you not satisfied with your actual GPC column?
Re: GPC column
Posted: Wed Aug 31, 2011 2:14 pm
by nschwartz
My experience is more with prep GPC, but I can tell you that you need to look at the molecular weight exclusion limit when choosing a column. If your largest analyte is 3 million amu, look for a MWEL of 3 million or slightly higher. Anything above 3 million will be excluded and come out first.
