QUATTRO MICRO API troubleshooting
Posted: Fri Aug 26, 2011 1:35 pm
"Turn LC pump off" is a part of my shutdown method. It usually works fine at the end of the sequence. But sometimes my sequence pauses in the middle (for no reason...), and when shutdown method is activated "at pause" as planned, it does not turn off the LC pump. Several times my probe compartment looked like a 1/3 full aquarium. It was not this high to damage my instrument, but overall this is a problem. I wonder if anyone has had similar experience, and found a remedy? So far Waters does not know either. I was thinking along the lines of minor and occasional power spikes interrupting LC -- MS communications... but this may not be the reason. Looking for an advice.
