2D GC_TOFMS column bleeding
Posted: Fri Aug 19, 2011 4:18 pm
by yuanzhang
Help me! :( I'm so confusing about the reasons of column bleed.
1st, where can I get evidence of column bleed? (Baseline rising when temp increase?)
2nd, how can I differentiate the column bleed between the first and second columns (or even MS)?
3rd, how can I determine the column bleed reasons, oxygen or thermal damage? Is there any test method?
Thank you very very much!~ :cat:
Re: 2D GC_TOFMS column bleeding
Posted: Sat Aug 20, 2011 3:21 am
by Don_Hilton
Column bleed it often indicated by a rising baseline and spectral characteristics of polysilanes being present.
In 2-D chromatography, the column bleed from the first dimension column forms a band across the chromatogram, eluting before other components in the second dimension. This band may include the tail of the injection solvent. Bleed from the second dimension column is difficult to observe as the second dimension column is short an narrow - thus has little stationary phase to bleed to start with - and what does bleed becomes a fairly constant signal in the background.
My guess on reasons for bleed is that both oxygen and heat damage every column to some degee. Other factors play a part as well, such as compunds that degrade the stationary phase and are introduced by injection in a sample.
