5890 II plus inlet temperature fluctuating
Posted: Tue Aug 16, 2011 4:14 pm
by faris
I had problem with the GC 5890 II plus, the inlet temperature is not stable, It is actuating by 5+/- from the set point, I did replace the heater/sensor assembly and also the main-board and also I did put more insulation in the inlet port with out any success. Do you guys have and idea about what is going on.
Re: 5890 II plus inlet temperature fluctuating
Posted: Thu Sep 29, 2011 3:33 am
by mkigls
You need to provide more information:
Setpoint of injector
Oven temperature, including program profile
Posted: Thu Sep 29, 2011 4:54 am
by faris
Thanks I got it fixed. It was the heater sensor assembly that i put new.
