I need help from you,
Posted: Sat Aug 13, 2011 9:47 pm
In GPC experiments, the chromatograms have a bad baseline. That usually happens after the first peak more intense, the baseline does not resume its original position (5mV), but lowers to zero, so I lose the information of the sample. The problem is more pronounced for the IR detector. I use polystyrene column for analysis of polymer samples.
