Heavier PAHs GC/MS
Posted: Tue Aug 09, 2011 7:23 pm
Hello everyone, i'm writing here because after months of tries i still can't get last 4 PAHs on my chromatogram.
I'm talking about dibenzo(a,i)(a,l,)(a.e)(a,h)pyrene, and i have some issues with indeno(1,2,3-cd)pyrene, dibenzo(a,h)anthracene and benzo(g,h,i)perylene too.
I have never seen the first 4 i mentioned, the only thing i see is a small unresolved peak (it's more like a hill actually) at the end of the chromatogram, and about the last 3 i can see them but they are very discriminated and bad shaped compared to the others.
I work on a Varian Saturn 3900/2100 in MS/MS, i have a varian factor four 5ms column 30m, 0.25 both ID and film.
Conditions are:
Injector: 300 °C with pulsed splitless @30psi for 0.5min, then split open at 50 ml/min.
Oven: 100 °C x 3min, @6°C/min to 320 x 20 min.
Xferline= 300 °C
Trap= 230°C
Manifold= 50°C (the real T is ~70°C)
I inject a STD mix 22 @2ppm (diluted by me) from an ultracientific solution.
The story is: i couldn't see anything past 202m/z, then i have read a topic in this forum where someone had his trap cleaned and his column cut and solved the problem so i did it as well and it actually worked, but i still can't get those.
The trap is clean, the column is cut, the PAHs are in the solution (std mix22 from ultra) the only thing i didn't check is the injector. Could it be the liner? If so which liner should i use? Currently i'm using a splitless with single taper.
The instrument works well, i think my problem is that i'm not getting the heavis in my system, can anybody help me?
i'm desperate with this.
Davide.
Conditions are:
Xferline= 300 °C
Trap= 230°C
Davide.
