Agilent 7820 GC vith valco gas sampling valve
Posted: Fri Aug 05, 2011 7:34 am
by silber
I'm interested in a Agilent 7820 GC with two channels:
FID for detection of low molecular hydrocarbons and TCD for detection of N2, CO, CO2, O2, CH4.
The main issue is the sample amount:between 100 and 200 ul.
I found a Valco GSV with loops of 25, 50, 100 ul and now the question is: would this valve fit into the agilent GC?
Nadia
Re: Agilent 7820 GC vith valco gas sampling valve
Posted: Fri Aug 05, 2011 11:46 am
by GasMan
You can install two valves on the 7820. These can be ordered with a new GC or there are upgrade kits if you already have a 7820. You should contact Agilent.
Gasman
