Is my peak shape OK?
Posted: Wed Aug 03, 2011 11:06 pm
Hello All,
I just wanted to get some opinions on my peak shape for a low concentration peak (500 ppb) of CO. I notice there is some tailing at the end of the peak, but what I do not have a sense for is what an "acceptable" level of tailing is. I know one can't get every peak in a method to look totally perfect, but what is too much tailing to make something quantifiable? I know it's especially an issue when dealing with such low concentrations as these.
Here are some chromatograms of a standard. The first is an overall picture of what is going on in the FID:
(I know the peak at the 6.7 minute mark looks like more of a problem. That's CO2. I'm not interested in low levels of CO2 such as this, 500 ppb, so this is acceptable for me.)
And this is a zoomed in shot of the CO peak, followed by the more symmetric CH4 peak (also 500 ppb).
Is the CO reliably quantifiable? If so, how should I draw my baseline? For previous analyses, I've been using the integrator with Chemstation, but should I be setting my parameters on that a certain way?
And in case it's needed, here are my process conditions:
GC = Agilent 7890A
Mixture: 0.1% H2, 500 ppb CO, 500 ppb CH4, 500 ppb CO2, balance N2
FID flow rates: H2 = 45 ml/min, Air = 500 ml/min, makeup (argon) = 30 ml/min, detector temp = 200 C
Column flow rate (argon) = 5 ml/min
Oven program = -80 C for 3 min., 60 C/min to 105 C, hold 1 min.
Column = 60 m GS-GASPRO
Valve Box T = 150 C
Nickel Methanizer Catalyst = 375 C
Injection Method - Via 6-port gas sampling valve, 30 second injection time.
Flow path - from 6-port valve, through column, into TCD, into Ni-methanizer catalyst, into FID.
fergman
GC = Agilent 7890A
Valve Box T = 150 C
fergman
