Increase of column backpressure
Posted: Wed Mar 30, 2005 9:30 am
we've been using a Kromasil C18 150-4.6-5µm (AIT packed) in routine analysis of synthesis crude (monitoring of Starting Material conversion + MS coupling for conformity of expected product mass). The most frequently used system is H2O-ACN, the column is used with a guard (phenomenex Secury-guard) and the column has 635 injections. The pressure is stil high, about 143bar @0.7ml/min for 30-70 ACN-H2O, despite i cahnged the pre-column and proceed a washing procedure of the column with inverted flow direction.
What can i do more ?
