Verification of USP Residual solvents <467> with USP <1226>
Posted: Fri Jul 29, 2011 8:48 pm
Our lab is in the middle of trying to craft a well thought out SOP for USP verification of compenial procedures <1226>. Residual solvents will be specifically addressed since it covers such a vast amount of raw materials.
Now I've been looking for information on this forum and came across this thread.
viewtopic.php?f=1&t=10231&hilit=USP+1226
Not the most exciting read, but a lot of information nonetheless.
Bottom line question here, how much is really needed to verify APIs with USP <467>? Regarding USP <1226>, as stated by krickos in the earlier thread;
Finally, does the standard addition aspect of the residual solvents procedure change how the verification chould be handled?
the versions are different. The original version of <1226> presented in 2005 had guidelines to some of the specific analytical performance characteristics applied to each catogory and whether it was for a raw material or finished product. The current version does not have this. Why is that the case?One thing to be kept in mind, though: The article is from oct 2005, after a quick glance, most likely based on the early drafts of chapter <1226> that in some cases more or less called for a complete revalidation in some drug product cases.
The final version of <1226> came out quite different in certain aspects. For the intrested I refer to Pharmacopeial Forum Vol 31(2) Mar.-Apr. 2005 page 555-558 if you like to compare.
